EAPS PDU being dropped because the EEP Length is greater than the length of the packet.
If the length in EEP header is greater than that of the entire packet length, it could be due to a programming error while setting the EEP length. Or if the EEP length itself is ok, then the packet may have been truncated. May have to capture the packet using a sniffer for further analysis.
Warning
%slotPort%, %vlan% - EEP Length (%EEPLen%) greater than packet length (%packetLen%)
| Name | Type |
| slotPort | SlotPort |
| vlan | VLAN |
| EEPLen | uInt |
| packetLen | uInt |
